vxtacy 1 Posted July 16, 2020 7 minutes ago, Dakotagrafx said: In your last picture t shows the software set at .3 offset, but is the software or the plotter itself actually setting the offset being used? i havent been able to locate an offset option on the machine Share this post Link to post Share on other sites
vxtacy 1 Posted July 16, 2020 2 hours ago, darcshadow said: That really looks like you're cutting into the backing paper. If so that means you still have too much blade exposed. No matter how much pressure you apply on a hard surface you should not be able to cut the backing if the blade is set correctly. i've adjusted further to make sure its a lot less than that now! thank you:) Share this post Link to post Share on other sites
vxtacy 1 Posted July 16, 2020 Managed to get my offset actually changing by deleting to reset the signcut folders in my appdata , far right is 1mm and middle .24mm -and left is .118 30 minutes ago, vxtacy said: Res Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted July 16, 2020 last picture of the t's looks the best - just add a little to your overcut now 1 Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted July 16, 2020 not what you are looking for but that 1mm is pretty cool effect 1 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted July 16, 2020 Yeah the T's look pretty good from here. The little tag at the bottom is probably from the blade being at a different angle when it is dropped and then it rotates into position as it starts to travel. Overcut like mentioned will cause the cut to run a smidge longer and connect the end to the start. Don't over-do it. 2 Share this post Link to post Share on other sites
