Guest Miriam mullen Posted August 27, 2018 So I’m using the vinyl master pro V4.0 and I see where the eraser tool is located but it won’t let me highlight it to use it. I have a monogram that has a circle around it that I need to erase the circle but leave the monogram intact, I am able to do this in my silhouette but I want to do this in VM pro. Help Quote Share this post Link to post Share on other sites
Scratchthejeepguy 77 Posted August 27, 2018 You should be able to either BREAK APART or UNGROUP it, then click on the parts you want gone and hit delete. Quote Share this post Link to post Share on other sites
darcshadow 1,627 Posted August 27, 2018 And if you can't get those to work, node edit and delete all the nodes is an option, although an annoying one to do. Does VM work with raster images as well? An eraser tool seems more of a raster image tool than a vector tool to me. Never mind, just looked up VM and the eraser tool, apparently it is a node editing tool so does kind of make sense. Quote Share this post Link to post Share on other sites
Guest Miriam mullen Posted August 27, 2018 Thank you I will try these options Quote Share this post Link to post Share on other sites
