craig165 0 Posted May 19, 2017 hi, i just upadated from flexistarter to flexi pro10 and have a few issues. when i import a transparent image it loads as a black box? when i contour cut an image and it does it fine but when i press the cut button i get this "no cuttable object with current settings"? i didnt have these issues in flexistarter but im sure its me not doing something correctly . thanks in advance. oh, and is there someway of importing the work i have saved with flexistarter and use in flexi10 as when i import it is just a blank screen ? if i import work from flexi10 to flexistarter its ok . Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 19, 2017 personally I would contact SAI directly so they can walk thru this - they are super on their support 1 Share this post Link to post Share on other sites
FrznFire07 217 Posted May 19, 2017 I use flexi quite extensively, they have serious issues with effects. Transparencies and shadows tend to be wrong almost every time. your best bet is to import as a TIFF file and then import your contour line separately. For whatever reason Flexi just can't understand gradient/transparencies/shadows. As for you cuttable object, is it a vector line? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 19, 2017 10 minutes ago, FrznFire07 said: I use flexi quite extensively, they have serious issues with effects. Transparencies and shadows tend to be wrong almost every time. your best bet is to import as a TIFF file and then import your contour line separately. For whatever reason Flexi just can't understand gradient/transparencies/shadows. As for you cuttable object, is it a vector line? mine got a lot better in ver 12 in those areas - 1 Share this post Link to post Share on other sites
FrznFire07 217 Posted May 19, 2017 35 minutes ago, Dakotagrafx said: mine got a lot better in ver 12 in those areas - yeah i have ver 11, and it gives me all kinds of crap, lol. Glad to see they're fixing the issues. Hopefully we'll upgrade next year. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 19, 2017 I use ve-lxi master plus and they just had an update to support svg files - Share this post Link to post Share on other sites
