kenimes 42 Posted April 5, 2007 SignCut LE importing from Inkscape correctly. Customer is having this issue and does not have easy internet access, so I thought I would post for her. I would have had her email me the file to test here, but no internet. Thank you, Ken Share this post Link to post Share on other sites
wg_kjell 0 Posted April 8, 2007 Hi, take a look at it in the preview. If she is able to see all of it there, she should also be able to cut it all, else not. Do she really have SignCut-X2 running in the LE-mode? I guess that she still have the TEST-mode? Or she may did not set the proper vinyl width in the cutter area of the Control panel. It may be too a small value there? Also try to reduce the letter size to see if that affects what comes out when cutting? If the size affect the result, then this must be a question of wrong program mode, I mean it is still int the TEST mode. Share this post Link to post Share on other sites
hotrodrichie 0 Posted April 10, 2007 wg i have had same thing and can not get it to work i did download a trial of corl and it does the job i still can not get inkscape to work Share this post Link to post Share on other sites
wg_kjell 0 Posted April 11, 2007 Hi, the reason may be that you have the latest revision of Inkscape, but not 2.16 of SignCut-X2? Else, please send a flle-example to: per@whisqu.se. Please describe exactly how you do the export! Share this post Link to post Share on other sites
