Pebbles1488 6 Posted January 7, 2017 I want to flip the image on the right from top to bottom, not side to side like the mirror image does. Anyone know how to do this or if it is even possible? Thank you in advance!! Share this post Link to post Share on other sites
Dawn's Design 403 Posted January 7, 2017 Is this what your talking about? 1 Share this post Link to post Share on other sites
Pebbles1488 6 Posted January 7, 2017 (edited) 7 minutes ago, Dawn's Design said: Is this what your talking about? YES!!!!!!!!!!!!!! How do I do that? Edited January 7, 2017 by deannasdecals I wanted to type more Share this post Link to post Share on other sites
Dawn's Design 403 Posted January 7, 2017 Glad I could help... 1 Share this post Link to post Share on other sites
Pebbles1488 6 Posted January 7, 2017 1 minute ago, Dawn's Design said: Glad I could help... Is there an option for that? I only figured out the mirror image option. Share this post Link to post Share on other sites
Dawn's Design 403 Posted January 7, 2017 What graphic design software do you use? Share this post Link to post Share on other sites
Pebbles1488 6 Posted January 7, 2017 Just now, Dawn's Design said: What graphic design software do you use? Sign Blazer Elements Share this post Link to post Share on other sites
Dawn's Design 403 Posted January 7, 2017 I've never done much with sign blazer. I use corel X6. Here they are in separate pics if that helps. Share this post Link to post Share on other sites
Pebbles1488 6 Posted January 7, 2017 33 minutes ago, Dawn's Design said: I've never done much with sign blazer. I use corel X6. Here they are in separate pics if that helps. You rock!!!! Thank you SO much!!! 1 Share this post Link to post Share on other sites
Jburns 239 Posted January 7, 2017 For SB, I select the image, right click - and then click the rotate button. Then right click again, and play with the rotation angles. 2 Share this post Link to post Share on other sites
Primal Decals 621 Posted January 8, 2017 On 1/7/2017 at 1:04 PM, deannasdecals said: I want to flip the image on the right from top to bottom, not side to side like the mirror image does. Anyone know how to do this or if it is even possible? Thank you in advance!! Reflect? Share this post Link to post Share on other sites
mb20music 760 Posted January 9, 2017 mirror - rotate - mirror again http://www.screencast.com/t/Y4BkTo5y Unable to display content. Adobe Flash is required. 1 Share this post Link to post Share on other sites
slice&dice 2,469 Posted January 9, 2017 On 1/7/2017 at 6:04 PM, Jburns said: For SB, I select the image, right click - and then click the rotate button. Then right click again, and play with the rotation angles. Bingo! In SignBlazer, right-clicking awards you with a range of oddities in a special menu that sprang from the mind of the creator, Jerry Bonham. But right-clicking won't allow copy-pasting! That's still reserved for keyboard commands. CTRL+C CTRL+V Share this post Link to post Share on other sites
