cardudenc 151 Posted October 27, 2016 VM came with my cutter. so I started learning to cut with this program. a few months later with recommendation and help from a friend I met on here I upgraded to scalps4. every now and then I get a call to do a decal I used vm to make. so I haven't moved anything, I just go into vm and open an old file to do the cut. The 1st issue I had was it would put a space in the txt when a file was reopened. I just reopened 1 and as I was about to hit cut noticed a weird line running thru the design. couldn't get a screenshot of it to post. only shows up when I hit area test , then fades away Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted October 27, 2016 It is showing you the path the blade will take which is not cut out. At the top of VinylMaster (Cut, LTR, Pro) you will see a link to update VinylMaster. Please run this. Quote Share this post Link to post Share on other sites
