wkeplinger84 0 Posted September 15, 2016 Hello everyone, I am new to the vinyl cutting and working with these machines. I have run into an issue I have it all hooked up properly and my computer reconizes it no problems there and it will also print/cut text fine if I write it myself on the software that came with it, but the issue that i am having is I am trying to take an image that someone sent me and cut it into a sticker for his company and it keeps saying there is nothing to cut. I have tried all the steps that I can find and it still says noting to cut. Can someone please help me. I have the MH-MK2 i think. Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted September 15, 2016 more than likely you was sent a raster image made of pixels - the cutter uses vector graphics which is a mathematical representation of an image with nodes and lines (arc for those in other communities) - you image must be digitized - depending on your software it may have a vectorize function or may not and will more than likely produce a less than desirable version depending on the quality of the original image. a redraw by someone with experience with drawing vector images produces the best results - cost vaty for that servie 1 Share this post Link to post Share on other sites
BannerJohn 1,324 Posted September 15, 2016 send me the image via message and I will do my best to vectorize it and send it back as a cuttable image. Share this post Link to post Share on other sites
