rayjb 2 Posted April 28, 2016 if these are the drivers i have no idea which one i need <div top"="" style="width: 187.594px; float: left;">Cutters MH Series GoldCut SC Series PCut LaserPoint LaserPoint II TC Series Copam ZenCut Silhouette Graphtec Roland Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 I think he meant "drivers" here.. Not had your coffee yet no coffee yet and I ment the drivers from my first post . . . The Titan isn't listed in the regular area as he found out from that last post and the reason I posted the link Share this post Link to post Share on other sites
rayjb 2 Posted April 28, 2016 no coffee yet and I ment the drivers from my first post . . . The Titan isn't listed in the regular area as he found out from that last post and the reason I posted the link ok, then yes i already did download the driver Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 Dang auto correct on the iPad and my old glasses were near it lol 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 ok, then yes i already did download the driversounds like it isn't installed then, on some you have to right click on them and add as an administrator Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 ok, then yes i already did download the driverspecifically the driver from the middle of the page from my first post? Share this post Link to post Share on other sites
rayjb 2 Posted April 28, 2016 specifically the driver from the middle of the page from my first post? I did that and it still says need titan edition Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 28, 2016 Ok so there is no confusion.. Which cutting software did you install? Vinyl Master Cut or Sure cuts a lot? Just making sure.. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 are you still on hold with support ? Share this post Link to post Share on other sites
rayjb 2 Posted April 28, 2016 are you still on hold with support ? yes Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 I just checked my vinylmaster pro and the titan is not listed so could be a problem with the edition you have and support will need to rectify. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 28, 2016 That is why I was asking.. As the ad with the Titan 2 states that Vinyl Master CUT that comes with the cutter. works with these cutters. This software will work with the following cutters: * USCutter Series MH, SC, Laserpoint II USCutter Series Table Titan, Titan, Titan 2 & Titan 3 Graphtec CE Series, FC Series Mimaki CG Series Roland GX Series Summa D, FX ,T Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 when i used mine to cut directly from corel (didn't like it as much as vm) I used this guide for set uphttp://www.uscuttersupport.com/downloads/vinyl-cutters/usb-guide/titan-2/Titan2_USB_WIN7.pdf Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 That is why I was asking.. As the ad with the Titan 2 states that Vinyl Master CUT that comes with the cutter. works with these cutters. This software will work with the following cutters: * USCutter Series MH, SC, Laserpoint II USCutter Series Table Titan, Titan, Titan 2 & Titan 3 Graphtec CE Series, FC Series Mimaki CG Series Roland GX Series Summa D, FX ,T I think they have different versions -mine is uscutter vm pro and it doesn't list the titan - I checked my installed version specifically - one of those things where they strip out the other drivers for a oem version and maybe the one he got is the wrong one - figure support will sort it out Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 28, 2016 Now aren't the Signblazer people using the Copam driver with the Titans.? Because they didn't want to quit using Signblazer Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 make sure to let us know what fixes it so we can search it in the future Share this post Link to post Share on other sites
Primal Decals 621 Posted April 28, 2016 Unless i missed it earlier, but didnt the Vinylmaster software need to be upgraded to the Titan edition to work? Just buying Vm wont work as far as i remember. Need the upgrade. Just Checking Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 Unless i missed it earlier, but didnt the Vinylmaster software need to be upgraded to the Titan edition to work? Just buying Vm wont work as far as i remember. Need the upgrade. Just Checking that should have been rectified by now - that was a problem early on with vm - 1 Share this post Link to post Share on other sites
slice&dice 2,451 Posted April 28, 2016 You might want to get in touch with FutureCorp. and give them a shot at this -- it's their software, and their support team perhaps is better suited to deal with this than USCutter. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 28, 2016 You might want to get in touch with FutureCorp. and give them a shot at this -- it's their software, and their support team perhaps is better suited to deal with this than USCutter. didn't we have a post a while back where someone tried that and ended up BUYING a new copy from futurecorp and it didn't have the titan included as it was a oem private labeled unit and then they had to get back with USC to fix the original problem anyways - USC has the version for the TITAN cutters that is specifically for this cutter - I mentioned this thread to someone at usc - hopefully someone will be with us or on the phone shortly to answer the call as the OP says they have been on hold for 2 hrs (never heard of it taking that long for someone that stayed on the phone either - so it should be sorted out and we hope to hear the fix soon 1 Share this post Link to post Share on other sites
rayjb 2 Posted April 28, 2016 stayed on hold 2 hours and got dropped have to leave, I will try future corp Share this post Link to post Share on other sites
rayjb 2 Posted April 28, 2016 Just sent a request out to future corp, will wait for the response and will try uscutter again Share this post Link to post Share on other sites
dave_dj1 39 Posted April 28, 2016 The only software I got (I actually didn't get any discs) was the VM CUT V4.0 if that helps? I did get a little padded envelope that said software included but it was empty. I guess I will contact them tomorrow and see what's going on. Good luck PS can you go to and download the software from their site? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 28, 2016 You can download the Demo from Vinyl Master and it does show all of the Titan cutters on it... Share this post Link to post Share on other sites
