bulldogwoodworking 1 Posted February 3, 2016 I was given a cutter by a friend. I know that she used it for t-shirts for her volleyball team. I cannot find a cutter brand on it anywhere. The blade housing says signwarehouse.com, but when I call them they want money to help me. There is only a model number on the back. PLT-CT with the 36 box colored in so I'm assuming it is a 36" cutter. Can anyone help me out so that I can download a manual and find out if SCAL works with this cutter or if I need to purchase other software? I have attached photos of the machine, model number and the control panel. Thanks all, Rebecca Share this post Link to post Share on other sites
mb20music 760 Posted February 3, 2016 Well it appears that it is a Signwarehouse R31 or Enduracut, which are rebranded cutters. Maybe go to the signwarehouse website and contact them via email and provide them with the serial number to see what info they can give on it. But, I am pretty sure you can run it with Signblazer Elements which is free cutting software. http://download.uscutter.com/SBEforUSCutterSetup.exe Share this post Link to post Share on other sites
RickS 39 Posted February 3, 2016 move the cutter out of the way so we can see the Bobcats. 3 Share this post Link to post Share on other sites
mfatty500 456 Posted February 3, 2016 Well, isn't that the Cat's meow.. Share this post Link to post Share on other sites
bulldogwoodworking 1 Posted February 3, 2016 Thanks for the help, MB20Music. Hopefully I can get Signwarehouse to help meowt. I figured I'd get some comments on the cat after I noticed it was in the picture. Thanks again,Rebecca 1 Share this post Link to post Share on other sites
busterbay 326 Posted February 3, 2016 Them ain't normal kitties in that thar house Share this post Link to post Share on other sites
Primal Decals 621 Posted February 4, 2016 here you go bud.. heres the main link to the page of the cutter. I found it to be a kcut pro. http://www.creation.com.hk/eng/eshowshop.asp?id=34 . i have the link for the manual. it wont let me post the link.. ill keep trying... Share this post Link to post Share on other sites
Primal Decals 621 Posted February 4, 2016 heres the manual----------------- http://www.creation.com.hk/eng/support.asp click on KINGCUT CT User's Manual(4.22) if you goto this page and click support it will get you the maual. for somereason its not liking the link.. http://www.creation.com.hk/eng/ KINGCUT CT User's Manual(4.22).pdfKINGCUT CT User's Manual(4.22).pdf Share this post Link to post Share on other sites
BearlyRich 167 Posted February 4, 2016 Just in case... Unless my memory's failing me: It looks identical to my PCut, still a Creation machine. BUT as I also remember, the KingCut is different. I don't remember why though. I found this out on the Creation web site back when I was investigating my 'new' PCut. I would give it a try with SignBlazer using the PCUT CT-900 driver setting and see what happens. Share this post Link to post Share on other sites
30-284 86 Posted February 7, 2016 Did you ever think to ask your friend what program they used with it? Share this post Link to post Share on other sites
PixelPusher 46 Posted February 23, 2016 You are correct in thinking your cutter is a 36" model. The other two options are 24" and 48" models. I am not sure what the difference is between the CT and A models are however. Here are drivers and user guides off of Creation's website: http://www.creation.com.hk/eng/support.asp which should help. It's a shame that Signwarehouse.com is charging you $200 to get assistance with your cutter, I'll file that in my brain somewhere as a company to avoid like the plague. Also, SignGo from http://www.signgo.com has a 30 day unencumbered trial you can download and try out. It's not the easiest software to use I've found however unforunately. But if you go this route, I may be able to help you. SignGo has their own forum too to get support on and they will reply and assist you. Share this post Link to post Share on other sites
