stealthie 0 Posted November 10, 2015 Hello I need some help. I just received my 24" LaserPoint 2 cutter and am working with Sure Cuts a Lot 4. I am ready to cut my first design, but when it comes to lining up registration marks with the laser the laser does not turn on and I cant line it up. It also does not turn on when trying to calibrate within Sure Cuts but does turn on when calibrating within the LaserPoint 2 settings on the cutter so I know it works. Does anyone know a solution to this problem? I tried searching anf have spend countless hours trying everything. Please help. Thanks Share this post Link to post Share on other sites
GraphxNMore 282 Posted November 10, 2015 Not sure about the LP2, but you have to turn the laser on manually on the SC & Titan II. You don't do it in the software. 1 Share this post Link to post Share on other sites
Primal Decals 621 Posted November 10, 2015 Not sure about the LP2, but you have to turn the laser on manually on the SC & Titan II. You don't do it in the software. True , i have to turn mine on manually as well titan 2 Share this post Link to post Share on other sites
