iam1ofhis
Rhinestone Spacing on Templates
I am using SCALP and am having a hard time using some scripts and getting the correct spacing so it doesn't look like junk. Is there a general rule for spacing of the rhinestones? And what is the preferred script for rhinestone templates?
The most important thing to remember when cutting rhinestone templates in scalp is make the holes 1 size bigger. So if you using 10mm them cut the holes 11mm. Perfered fonts. You have to work with them and spacing depends on the font you use. What kinda cutter are you using and make sure you have a 60* blade. I do 2 passages when making my template
I also buy font packages from the rhinestone world
djque - I am using the USCutter SC series with a 60 degree blade. What is the best script font to use in SCALP?
