VinylRevamp 93 Posted May 8, 2015 Hey guys, I was trying to do this multi color design on a tank top but as you can see by the picture, the colors got smaller after pressing leaving some space between them. I press each color down for a few seconds, then pressed for the full time altogether. What would be the best way to do this? Thanks Share this post Link to post Share on other sites
jaybyrd 3,770 Posted May 8, 2015 I'd suggest cutting the coral? and lilac? so they are touching each other and the using the blue to cover the seam. Share this post Link to post Share on other sites
Sue2 920 Posted May 8, 2015 Cute design! I can barely see the space between the colors you are referring to. Sometimes we are our own biggest critics... If you want to "fix" it, go into your vector file and make a thin overlap of the colors onto the blue.....or enlarge the peach & lilac a bit and apply the blue over them like jay suggests. Sue2 Share this post Link to post Share on other sites
VinylRevamp 93 Posted May 8, 2015 Thanks for the advice! I was thinking of shadow layering the blue to make it a little thicker. That would have probably covered the white area. The blue was the first color i pressed down so i can have the alignment for the other colors. Was to afraid to try it a different order, but i guess that's how im suppose to learn.... Thanks again Share this post Link to post Share on other sites
