elgusta 0 Posted April 11, 2008 have trouble hack into Flexi 8.1 because I signblazer works well but not flex rose short but I skate all the work leaving unusable work Instead on signblazer I rose well short and well Share this post Link to post Share on other sites
kenimes 42 Posted April 11, 2008 SignBlazer works fine but you are having troubles with Flexi, if I understand correctly? You should select the Creation PCut CT630 driver for your LaserPoint with Flexi, but you will not have contour cutting capabilities with Flexi. Share this post Link to post Share on other sites
Guest Terry Posted April 12, 2008 Flexi does contour cuts, I used it all the time at my last job on the Roland,,, but it was Flexi pro. Share this post Link to post Share on other sites
Guest fivestar Posted April 12, 2008 I "think" Ken was referring to it not contour cutting with US Cutter's laser cutter. It would be nice if it did though for people whating to use it. Share this post Link to post Share on other sites
haumana 1,221 Posted April 12, 2008 okay, honestly ... I'm just totally confused. Share this post Link to post Share on other sites
