frizz6907 0 Posted January 6, 2015 I'm trying to get the background pattern to come through the owl. I'm using SCAL 3 pro. Normally I would select both images and "front minus back", but for whatever reason, it's not working. The background is a googled image I placed on the page and the owl is a traced image. I also have Inkscape and Photoshop CS6. I am VERY unfamiliar with both of those. My ultimate goal is to use the design for DTG with Chromablast, which I've never done either. Thanks! Share this post Link to post Share on other sites
30-284 86 Posted January 7, 2015 Is this what you are trying to accomplish? Get the pattern to come thru in the owl? Share this post Link to post Share on other sites
frizz6907 0 Posted January 7, 2015 Yes!!! Normally I have no problem doing it in SCAL, but for whatever reason I can't get it to work with a placed image instead of a traced image. Share this post Link to post Share on other sites
30-284 86 Posted January 7, 2015 First off the image would probably need to be vectorized, but even so, when you cut, the only color it will be is the color of your vinyl as unless your are using a printer/cutter this won't work for you. I did it in corel. Donn Share this post Link to post Share on other sites
frizz6907 0 Posted January 7, 2015 I'm going to print it. I got a RIcoh printer and Chromablast for Christmas and I'm trying to get it all figured out. I've never done it before and this design is something a customer wants. Share this post Link to post Share on other sites
30-284 86 Posted January 7, 2015 Only thing I would know to do would be to print the pattern on a piece of vinyl and then insert it into the cutter and cut the owl pattern out of it, but that's because I'm not real up on all of the programs. Otherwise post both the owl and the pattern and I will make the file for you and repost it. Donn Share this post Link to post Share on other sites
frizz6907 0 Posted January 7, 2015 For whatever reason, I'm not able to attach the images now. UGH! This has been so frustrating. Thank you for helping. I'll try again in a little bit. Share this post Link to post Share on other sites
GraphxNMore 282 Posted January 7, 2015 You mean you can clip with SCALP? I've NEVER been able to...... Am I missing something?? LOL Share this post Link to post Share on other sites
30-284 86 Posted January 7, 2015 I haven't either, I use Corel for that. Share this post Link to post Share on other sites
frizz6907 0 Posted January 7, 2015 In SCAL I'm normally able to do this when I'm using 2 traced images. I'm assuming my problem is arising because the background pattern isn't traced. Anyone explain how to do it in Photoshop, keeping in mind I'm totally new at using it? Share this post Link to post Share on other sites
skarekrow 1,842 Posted January 7, 2015 In Photoshop;Put your background layer over top of your owl layer.Select the Background (top) layer & mover cursor to a position between the two layers.Hold down 'ALT' (Option on Mac) and left clickThis will make a clipping mask out of it.Save to a suitable print format. (edit: these instructions are assuming you have the owl layer 'cut out', without a background.) Share this post Link to post Share on other sites
frizz6907 0 Posted January 7, 2015 Ok, so I did the clipping mask thing. It didn't work. I can make it work with text but it won't work with the owl. Is there a certain type of format it has to be in? I typed in some text and it worked perfectly, so I have the steps down. I just don't know why the owl won't work. Share this post Link to post Share on other sites
skarekrow 1,842 Posted January 7, 2015 You can try selecting the white of the owl (magic wand is one way) and then the same procedure I listed above. While you've got it selected I would 'control J' and create a new layer from the selection. Just make sure the background is above the owl layer you are trying to clip to. You can shift-click on the thumbnail of the owl in the layers pallet and see if it is selecting just the owl outline or if there is a background on it as well. If the owl layer was a jpg that you imported into Ps it has a background that must get removed or at least ignored for the clipping to work. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 8, 2015 Do you have the full suite in CS6 or just Photoshop? Share this post Link to post Share on other sites
