jaybyrd 3,770 Posted November 12, 2014 Is there anybody on here using the arms setup on a q75 cutter? I'm trying to figure out some stuff and would love to talk with someone with knowledge of this setup. My cutter says arms3.0 on the carriage but it isn't listed in the menus as being there and for all I know I could just be overlooking something simple. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 12, 2014 According to the instructions on mine Fc7000. You can push the KEY button next to ORIGIN that reads..... I am not at home right now will be tomorrow........ Go thru the menu, NEXT, NEXT, NEXT, NEXT.... Look under advanced...F4... AXIS/R.M.S. key: .....Press AXIS/R.M.S. to initiate automatic reading of the regis- tration marks. If Off has been selected for the registration mark mode, this key is used to perform axis alignment I would think your menu should be close to mine. http://www.graphtecamerica.com/docs/User_Manuals/CutPlot_UM/FC7000MK2-User-Manual.pdf Share this post Link to post Share on other sites
jaybyrd 3,770 Posted November 12, 2014 I think mine is set to off and I don't know how to turn it on. Share this post Link to post Share on other sites
mb20music 760 Posted November 13, 2014 With the media set lever in the up position, hit the initial menu key. Do you have "Auto Reg. Mark" shown as an option in the menu? Should be the first option in the menu. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted November 13, 2014 No its not there. That's what stumped me Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 13, 2014 what happens when you push the F1 or F4? After the what he says above? Share this post Link to post Share on other sites
jaybyrd 3,770 Posted November 13, 2014 F1 has nothing there to select. F4 is to select command type. It should show arms on F1 which has me stumped and I know not all Q series have ARMS but this one has a badge on the carriage that says arms 3.0 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 13, 2014 Maybe contact Signwarehouse at this point.... Share this post Link to post Share on other sites
jaybyrd 3,770 Posted November 13, 2014 That's what I was dreading. Heard so much about their customer support and not much of it was ever good. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 15, 2014 Sorry I forgot.. In case you didn't get it MENU> then 3 NEXT, you should see a BACK GROUND SETTING click F2 Then go 12 NEXT,,,, my screen says MARK AUTO SCAN F3 is ON.. F4 is OFF This is the place where I have seen it in BACK GROUND SETTINGS. This is also where I disable the media and pinch roller sensors. Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted November 15, 2014 Maybe you need some TNT! Good luck! Share this post Link to post Share on other sites
