Jbrooks02 1 Posted October 7, 2014 I have a USCutter mh871 mk2 and for some reason the vinyl just started running crooked through the machine. I've adjusted the pressure screws that clamp on the vinyl and all. Just need some help getting the vinyl back to running straight. Thanks. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 7, 2014 two things, always pre feed the vinyl so the machine is never pulling it off the roll. second is run it back and forth some to make sure you have it loaded straight. more people have cause problems playing with the pressure than solved them - the next thing they do is back it way off so the grit rollers don't leave marks - which is normal and then have tracking issues. too much blade exposure will also affect the tracking Share this post Link to post Share on other sites
Jbrooks02 1 Posted October 7, 2014 Thanks for the info. I'll try all of the above. Hopefully it gets me hooked up. 1 Share this post Link to post Share on other sites
Jbrooks02 1 Posted October 7, 2014 What's the best way to set the blade and how much sticking out? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 7, 2014 from our friend mz skeeter To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. 1 Share this post Link to post Share on other sites
Jbrooks02 1 Posted October 7, 2014 Ok thanks again for the help hopefully it all works out Share this post Link to post Share on other sites
signyouup 178 Posted October 7, 2014 Make sure the middle roller is over a grit roller and not between them. Share this post Link to post Share on other sites
Jbrooks02 1 Posted October 7, 2014 Yes I made sure of that lastnight and should the vinyl rollers all be set equal? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 7, 2014 What amazes me is that you ever got the MH to cut straight to begin with. 2 Share this post Link to post Share on other sites
Jbrooks02 1 Posted October 7, 2014 It was perfect when I got it Share this post Link to post Share on other sites
Wildgoose 4,200 Posted October 8, 2014 Double check that your pinch rollers are actually over a gritty section of the drive shaft. When was a young wart hog I made the mistake of sliding the pinch roller over and it was on the slick shaft on one side and it messed me up for longer than it should have before I figured it out. 1 Share this post Link to post Share on other sites
