wyatt0124 0 Posted October 2, 2014 hey guys, my blade when it starts moves to home point like it is suppose to, then once it gets to the home point acts like its trying to continue to go and makes a lot of noise…. any body know anything about this? Share this post Link to post Share on other sites
skener 11 Posted October 29, 2014 Hi it's not trying to cut past the stops or the end of its travel is it? sort of trying to go further than it's suppose to just a thought. Share this post Link to post Share on other sites
GraphxNMore 282 Posted November 21, 2014 Look at your workspace and make sure there's not anything past the edge. If you start in the middle of your cutter and select current position as starting point, the software will tell the cutter to keep moving to reach other cuts. Share this post Link to post Share on other sites
slice&dice 2,469 Posted November 22, 2014 The cutter head is not making contact with the electronic switch that says "Stop Here" --- that switch is located under the top cover on most machines, and usually all you have to do is slightly bend the metal contact strip a bit and it'll function correctly as the cutter head hits it. Share this post Link to post Share on other sites
