efimage 42 Posted August 27, 2014 I had to convert some bitmaps to vectors the other day and 2 of them had a lot of very sharp angles which caused some lifting. I ended up editing most of the nodes and everything ran fine. Being fairly new to cutting I was wondering if you guys have come across a design and decided it was not even worth fixing or would have been way too much time. Are there some angles you see in wire frame mode and know right off the bat that it needs to be edited? Share this post Link to post Share on other sites
MZ SKEETER 4,710 Posted August 27, 2014 I never have a problem with sharp angles, usually vinyl lifting is too much blade exposed, or too much speed. 1 Share this post Link to post Share on other sites
efimage 42 Posted August 27, 2014 Blade is set correctly I am running a Clean Cut 60 degree. No problems cutting so far. I might have been running a little fast at 15cm/s for this job. I attached an example of the problem area. I had to go into the vector and round off all the tips to get it not to lift. The final product looked the same after the editing. Share this post Link to post Share on other sites
MZ SKEETER 4,710 Posted August 27, 2014 Yes, you have to change speed for different jobs, that are more detailed. I slow down also for very small text... Share this post Link to post Share on other sites
MZ SKEETER 4,710 Posted August 27, 2014 I think it has also been said by users who have used both a Roland and a Graphtec that the Graphtec is much better with very detailed designs. I have never used a Roland,, but I know my Graphtec does great with very detailed designs. I don't use a Clean Cut blade, never have. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted August 27, 2014 One thing to consider is those points will tend to lift when installed due to the minimal surface area. 1 Share this post Link to post Share on other sites
efimage 42 Posted August 27, 2014 Thanks for the tip Jaybird. I did not even consider the installation side of it for these decals because they were ready to apply that but makes total sense. The decals where pretty small and detailed 4x5 inch total. I questioned there design to begin with because it looked really bad but that’s what they wanted. Share this post Link to post Share on other sites
Sue2 920 Posted August 29, 2014 Thanks for the tip Jaybird. I did not even consider the installation side of it for these decals because they were ready to apply that but makes total sense. The decals where pretty small and detailed 4x5 inch total. I questioned there design to begin with because it looked really bad but that’s what they wanted. Sometimes you have to say NO to what the customer "Wants". YOU are supposed to be the expert. Inevitably, if those teeny rays don't stick well, you or your materials will be blamed first. I guess this is good place for a written warning that the customer has to acknowledge. Sue2 Share this post Link to post Share on other sites
