KYSIGN 233 Posted October 24, 2013 I have 10 Yards of enduraTex Iron-On that I would like to use with my heat press. Has anyone tried using it with a press? What time, heat , and pressure did/would you use? Thanks. Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted October 24, 2013 Just type that question into google. Share this post Link to post Share on other sites
KYSIGN 233 Posted October 24, 2013 Just type that question into google. That's the first thing I did. The second was to search here. I have seen the question asked elsewhere but no answer. If you are seeing a result in google then share the link please. Thank you. Share this post Link to post Share on other sites
KYSIGN 233 Posted October 24, 2013 The EnduraTex Iron-On is 3.7 mil and Siser EasyWeed is 3.6 mil. The EasyWeed calls for 302ºF/150°C for 10-15 seconds, medium pressure. I think I will give this a try for the Iron-On. I'll test it out and post back in a few days. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 24, 2013 http://lmgtfy.com/?q=enduraTex+press+instruction Share this post Link to post Share on other sites
KYSIGN 233 Posted October 24, 2013 http://lmgtfy.com/?q=enduraTex+press+instruction I am talking about the EnduraTex Iron-On. It is normally applied using a clothing iron using the cotton setting for `1m 20s. I wanted to apply it with a heat press which will require different temp and time. I simply wanted to know if any members had success using it with a press and what settings they used. Thanks. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 24, 2013 I can honestly say that until I read this post I had never heard of it. Sorry I can't be of help on this 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 24, 2013 you are correct different time as the iron would have to be all over the place . . . personally would use the siser time and temp referenced above . . .like you said 1 Share this post Link to post Share on other sites
KYSIGN 233 Posted November 3, 2013 I used the Siser EasyWeed settings 302ºF/150°C for 10-15 seconds (I did 15 seconds), medium pressure. I waited 24 hours before first wash. It seems to work fine. The test shirts I made look great even after ~8 Wash/Dry cycles. 1 Share this post Link to post Share on other sites
