68Blkbrd 2 Posted October 7, 2013 I use Graphtec CE6000-60 and Illustrator CS6 with Cutting Master 3 software. I am noticing on my rounded counters (insides of my letters) the cuts don't seem to meet up. (Examples "O" and "e") Maybe 1/64th off (not short but offset) but giving me a weeding issue. Is there a setting to adjust so these cuts will join up? It only happens on the round counters not the angled ones. Thanks! Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 7, 2013 I don't know if CM3 has it but in Flexi I just bump up the overcut a hair to help them connect. Share this post Link to post Share on other sites
BCOJdecals 39 Posted October 8, 2013 I use the same setup as you...same cutter and software...however, I don't create my files in Illustrator. I create them in Make-the-Cut, export as .eps, then open with Illustrator to send to CM3...no issues whatsoever. Share this post Link to post Share on other sites
Boom 7 Posted June 29, 2014 I use S3 with cutting master 3 with no problems with the cuts. Many my setting are set slightly different.. The trouble im having is I cant figure out how to change the orientation of what cuts. The plotter self measures(say,15"x3 yards. I make 1 row of the decal but it cut the 3 yard length and not the 15" length. It has to be a setting but I cant figure it out... anyone? Share this post Link to post Share on other sites
