JoeCamaro 11 Posted March 19, 2008 I have been asked about how to prepare an artwork for layering and how to puch numbers into an item. I tought this might be of interest for many of the forum members and that is why I prepared this tutorial. 1 Open Illustrator and make a new blank document. 2 Type your text. I used the word Telephone for the tutorial. 3 Convert it to outlines (also knows and paths, object or curves) by going to Type > Create Outlines 4 Copy the item by going to Edit > Copy or ctrl+c on pc 5 Paste in front of the item by going to Edit > Paste in Front 6 Change color of the new item that has been pasted in front. (*Note: Dont click anything in the artboard, we need to keep this new item selected all the way.) 7 Send item to the back of the original item by going to Object > Arrange > Bring Backward Original item (black one) should be on top. 8 Go to Object > Path > Offset Path This will make the bottom layer bigger. 9 A window will open. As Im using a small text I have to start with small values in the offset blank. I used 0.006 to start. Here you will have to play until you get something you like. If you put a value and you dont like it go to Edit > Undo or ctrl + z and then do this step again. After value is entered this is how it will look. Red item (bottom layer) will grow bigger. 10 Save as an eps and cut it! Pretty easy, isn't it? BONUS TUTORIAL: Punch things to make various elements look good in one color decals. 11 Lets say you want to add flames to the word telephone and you want to make it one color. Draw or place your flames (or any object you want) in the artboard. 12 Select it and send it to the back by going to Edit > Arrange > Send to back 13 Select the red Telephone Layer and the Flames. (To select multiple things select the one on top, hold down the shift key and select the other element, then release shift) 14 Go to Window > Pathfinder 15 With items selceted click on Substract from Shape Area in the Pathfinder window. 16 Change color as desired. 17 Cut it and You are done! I hope this tutorial was clear and of help for you. If you have doubts just ask. Happy cutting! JoeCamaro Share this post Link to post Share on other sites
cutme 5 Posted March 19, 2008 thats really awesome! have you posted that in the tutorial section? i wish i had adobe illustrator. so far i am pretty sure i can do all that in signblazer though. thanks for the tutorial though i think i can actually apply some of that same principal in signblazer. i will have to try something like that. bb Share this post Link to post Share on other sites
Countryside Graphics 0 Posted March 19, 2008 way to go Joe I will show the flames when I het them finished... Share this post Link to post Share on other sites
HHeaglepub 0 Posted March 19, 2008 Joe - Thanks for the post - I am a new illiustrator user and this is very helpful! Share this post Link to post Share on other sites
Countryside Graphics 0 Posted March 19, 2008 Has anyone tried this Joe helped me and I still cant get it to work out right at the end when putting the 2 together Share this post Link to post Share on other sites
Countryside Graphics 0 Posted March 19, 2008 This is as far as i can get it to work for me 881-13.eps 881-13.eps Share this post Link to post Share on other sites
JoeCamaro 11 Posted March 19, 2008 There was nothing wrong with it. I just changed the color of the rectangle to get a better view of it. Then I selected the red 88 (make sure you select the red one and not the black one) and while holding shift down clicked on the yellow rectangle. Then went to Pathfinder and clicked on substract. That was all. Attached is the file for you to see 881-13.eps 881-13.eps Share this post Link to post Share on other sites
Countryside Graphics 0 Posted March 19, 2008 I was talking about getting the numbers to show up on the flames that is what I am having a problem with. Thanks Share this post Link to post Share on other sites
Countryside Graphics 0 Posted March 20, 2008 Ok I tried this and and got the photo the way I wanted it but the numbers want saty with the flames when I move it. Here is photo when I made the decal in illustrator and also a pic after trying to the cut. Can someone tell me what I have done wrong. Was this meant to be a layered decal with the numbers on the decal if so that is not what I was wanting. I am wanting the numbers to be in the flames and cut around the number and let the flame like fade into the numbers so it will be one big decal. Thanks 8822.eps 8822.eps Share this post Link to post Share on other sites
kenimes 42 Posted March 20, 2008 Probably need to combine or group the two together. Share this post Link to post Share on other sites
Countryside Graphics 0 Posted March 21, 2008 That worked but cut the number when it came across to make the flame is there anything I can do to make it pick the cutter head up and skip over the 8 and then cut and raise up again? Share this post Link to post Share on other sites
Alillowr 0 Posted March 24, 2008 I also am having problems trying to get this to work correctly. I could do the first half of instructions and it comes out fine, but when I try and do the second half at the end, I cant get it to come out nice like its supposed too. Not sure where I went wrong. Here is a picture of the results and also the file if it helps. helpme.eps helpme.eps Share this post Link to post Share on other sites
Alillowr 0 Posted March 24, 2008 Also here is the graphic in its original form that I wanted to use with the text. 32153171.eps 32153171.eps Share this post Link to post Share on other sites
JoeCamaro 11 Posted March 24, 2008 Do you have 2 Edit Me Items? You should have 2 and one must be bigger (the one on the back) that the other. I will check the file as soon as I get home later today. Joe Share this post Link to post Share on other sites
Alillowr 0 Posted March 24, 2008 Yep there are 2 edit me items. Im not sure if I did a few undo's by the time I took the screenshot and saved the file ( I was trying to go back and figure out a way to fix it) but I had it right with the text being black and the offset text being red. From my picture it looks like the arrangement was wrong when I saved the file to post. Share this post Link to post Share on other sites
Goodwin 0 Posted May 26, 2008 Quick question, when doing the basic two tone text would you punch the background so that the other colour fits inside? or keep both layers complete and layer the smaller letter ontop of the outline layer? Share this post Link to post Share on other sites
JoeCamaro 11 Posted May 26, 2008 I wouldnt punch it. It is easier to just place the small layer on top of the big layer. If you punch it then you have to perfectly align it inside, which can result in a great challenge. If you would still like to punch it, then you would need to make to copies of the smaller layer, one of them to use as a punh and the other to cut. Joe Share this post Link to post Share on other sites
Benr98 40 Posted May 26, 2008 Hey Joe, when are you going to set up training in PR for this?? Share this post Link to post Share on other sites
JoeCamaro 11 Posted May 26, 2008 Well I need to confirm the amount of people that would attend it. Would you attend a sign prep class in a tropical paradise? Joe Share this post Link to post Share on other sites
Benr98 40 Posted May 26, 2008 Most definitely!!!! I find ALOT easier when someone SHOWS me what to do!! Jenny Share this post Link to post Share on other sites
jaembroidery 0 Posted July 16, 2008 Joe, That is great for someone that uses AI but I have Corel and not AI. Any suggestions or help is greatly appreciated. I have to start on this trailer for this fire dept this weekend with outline letters allen Share this post Link to post Share on other sites
JoeCamaro 11 Posted July 16, 2008 Most programs have similar functions and processes. I have no experience with Corel. Cant you figure it out in Corel based on this tutorial? I would suggest you do a search for Corel Tutorials or check here: www.pixel2life.com or post a help request in the proper software help board. I am sorry I cant be of much help. Joe Share this post Link to post Share on other sites
new2this 1 Posted August 16, 2008 ok i kinda understand that, but what is the cutting process, if your cutting 3 colors whats the process Share this post Link to post Share on other sites
JoeCamaro 11 Posted August 16, 2008 cut each layer (color) individually. It your art has 3 colors, then when you go to your cutting software you set the size with all 3 layers selected, then there should be some squares (swatches) with the colors of the job, one square per color. You then click on the color you want to cut first, load the vinyl and cut, then click the next color, load vinyl and cut. Joe Share this post Link to post Share on other sites
