Scotth20 0 Posted August 25, 2013 I have the UScutter MH, just hooked it up. My issue is that when the test cut is performed, it works perfectly, only going over the image with one cut. When I attempted to cut a Pitts Steelers logo, it went over that image several times, which messed the entire image up. What am I doing wrong? I'm new to this, so any and all advice is welcomed! Share this post Link to post Share on other sites
MrMopar64 47 Posted August 25, 2013 put the image in wire frame and see if there is more than one layer. Also in some programs there is a setting for the number of passes you want to make MM64 Share this post Link to post Share on other sites
WHIT72 36 Posted August 25, 2013 Is the logo vector, did you trace it? If you grabbed it of the internet it may be a different format. Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 25, 2013 "Pittsburgh Steelers" There's the main problem, yes indeed !!! Go Ravens --- 1 Share this post Link to post Share on other sites
petroman2012 168 Posted August 26, 2013 New York Giants RULE.... Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 26, 2013 Giants www.youtube.com/watch?v=1JqvmGON0AM Share this post Link to post Share on other sites
petroman2012 168 Posted August 26, 2013 THATS SO FUNNY..NO LIE... Share this post Link to post Share on other sites
joker 618 Posted August 26, 2013 Giants hahaha... Go Cowboys 1 Share this post Link to post Share on other sites
cowboym31 1 Posted September 23, 2013 Sounds like too many layers, I was having the same problem. GO COWBOYS!! 1 Share this post Link to post Share on other sites
Ammastor 4 Posted September 29, 2013 I like the guy above me. GO COWBOYS.... lol I have used several vectors from a few popular sites for the Pittsburgh logo and several of them are in layers. And will cut multiple times. What cut software are you using? If you need another logo that you can test with let me know. Found one just this morning as someone wanted one. Its been cut and is in only 1 layer. Share this post Link to post Share on other sites
Ammastor 4 Posted September 29, 2013 Giants hahaha... Go Cowboys not that it matters but I have that same tattoo on my leg that you are using for you avatar. Share this post Link to post Share on other sites
