mstrachan 0 Posted August 14, 2013 I was cutting some vinyl when my cutter went dead. I post a video of the symtoms after it went bad. It makes this tapping noise and the lights flicker. Can this be fixed or do i need another cutter. What do you guys recommend. Here is the video Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted August 14, 2013 contact tech support. 1 Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted August 15, 2013 I was cutting some vinyl when my cutter went dead. I post a video of the symtoms after it went bad. It makes this tapping noise andthe lights flicker. Can this be fixed or do i need another cutter. What do you guys recommend. Here is the video I have 2 MH 721 Cutters.. this happened to me when mine was still under warranty They sent me out a new " Power Supply and Motherboard " and then it worked perfect.. I would replace the motherboard.. http://www.uscutter.com/MH-Series-Refine-Motherboard-MK2 I think mine got a static shock when mine went bad... Share this post Link to post Share on other sites
slice&dice 2,469 Posted August 15, 2013 How comfortable are you in disassembling the machine? You can try to pull it apart, removing & putting back the power supply and motherboard and maybe, just maybe, it will just regain its life. Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted August 15, 2013 It's vary easy to take apart.. there is like 6-8 screws on the bottom .. Share this post Link to post Share on other sites
