tysan 5 Posted June 16, 2013 I have done a two color sticker twice for my boat and when I apply it , it has tiny air bubbles under it .. I'm using oracal 651 vinyl with a wet install , will they go away when it dries or is something I'm doing wrong!!! Any ideas would be appreciated... THANKS Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 16, 2013 lots of fluid and slow your roll - squeegee carefully as you lay it down from one side to the other -practice will get you there Share this post Link to post Share on other sites
Carmigirl 7 Posted June 16, 2013 Are you layering the second color on top the first leaving the application tape you used to apply that second layer? Are you putting second layer on dry. You might be getting the bubbles then and not when you are applying it to the boat. Share this post Link to post Share on other sites
Carmigirl 7 Posted June 16, 2013 The reason I asked if you left application tape on after second layer and then going straight to applying to boat you are not seeing the bubbles are there from dry applying to first layer and not applying wet to the boat... Am I rambling... Ha Share this post Link to post Share on other sites
tysan 5 Posted June 16, 2013 Yes I am applying the second layer dry with the application left on , can you use fluid to put on second layer?? I didn't know you could... I am learning !!!! Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 16, 2013 layer it right on the boat with app fluid on both layers - 2 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted June 16, 2013 Layering always work best when you can do it on the finished product. Share this post Link to post Share on other sites
tysan 5 Posted June 16, 2013 Thanks everyone for the help you guys are awsome!!! Any good ways to remove the bubbled one, they stick good!! Share this post Link to post Share on other sites
BannerJohn 1,324 Posted June 16, 2013 Blow dryer or heat gun. Peel while hot. Share this post Link to post Share on other sites
Carmigirl 7 Posted June 16, 2013 Bubbles are always frustrating! Yes if you can put on boat single layer at a time wet you'll do fine. Just squeegee enough and let set for a minute. I used to get anxious and pull off too soon and cause bubbles. Good Luck and know you'll have it down in no time! As for bubbles disappearing...sometimes they do and sometimes not. Share this post Link to post Share on other sites
Carmigirl 7 Posted June 16, 2013 Also you can use fluid to build your decal but if the back gets wet and you pull vinyls off you'll have a mess. If you try this way and back gets wet let it completely dry first. Share this post Link to post Share on other sites
