toptensports
arch a text
You should be able to just type out your text then select all and ungroup the letters, rotate to your desire arch and when happy select all again and click on group all and save, or at least that is what I have done. Hope that helped you or one thing about a computer, Nothing is permanent until you save it try and try till you receive the results you like.
Draw your arc using the bezier tool and get the shape you want the text to follow.  Then use the type text to path tool (sounds like you are doing that already - it is under the text button in the toolbar in case you aren't already using it.)  Click on your path while you have the type to path tool selected and type the team name.
If the text goes the wrong way around you need to reverse the path of your line(or shape)
