dzine
Cutting wrong size HELP!
im having an issue posting pictures. Do I have to link to them? I am not sure how to upload, in these forums.. I swear, I am not computer illerterate. However, as I look, I do see output size compensation, and it is not enabled. I will play with this, and see if this helps. When I said seperate, meaning, break apart and cut sections seperate. If I am weeding something, and mess up say a letter, I can not go back and break apart the word, and cut just that letter to replace. The size will be off. I would have to cut the entire decal again, if I wanted it to be spot on.
Your cutter is a REDSAIL, you can probably use Signblazer with it.
Signblazer? Different cutting software?
Problem Fixed. It was panel size, and now if I send a 5x5 box, it cuts just that.. Thank You..
