mwhatch 9 Posted January 13, 2013 I would like to show these two sets of stickers. The first is some model race card numbes. The second is for my son that works for Quick Trip. The QT stickers were assembled on an index board that I made. I use my cameo to cut out 2-4 1/4 holes, then I can use the wooden dowel to pin each layer exactly where they need to be for precision location. Another advantage to using the index board is that you don't use as much vinyl as you would with index marks. You can put the holes within the body of the decal. Thanks for looking. Morton Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 13, 2013 Great job...your catching on fast!!! Share this post Link to post Share on other sites
louis clarke ii 202 Posted January 13, 2013 Intriguing. A little more info??? Share this post Link to post Share on other sites
HFD242 0 Posted January 13, 2013 cool idea with the index board. I just got cameo for xmas, been messing around with it. Share this post Link to post Share on other sites
mwhatch 9 Posted January 13, 2013 Thanks. I made the index board with a hobby cnc, the Carvewright. I drilled 1/4 holes on a 1 inch grid so if you use your cutter, like the cameo, set on heavy cardstock, it will cut all the way through the vinyl. Just make sure you put your index holes on 1 inch grid spacing to match the grid. Then you just have to figure out the sequence for layering your decal. Also, you need to use the cutting mat. I got some Cricut mats and like them a lot better. Morton 1 Share this post Link to post Share on other sites
Jay2703 704 Posted January 14, 2013 Great way to index your layers. Share this post Link to post Share on other sites
Precision Graphics 0 Posted January 14, 2013 nice work Share this post Link to post Share on other sites
