dmike 0 Posted December 15, 2012 Hi, I am new to this. Does anyone know if Corel 11 is compatible with the Copam 2500. I have a friend that is well versed with Corel Draw 11, so I feel like I could seek his help alot more easier if I were to use the same software as him. Thanks in advance for any help or wisdom you can provide ! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 15, 2012 Corel 11 compatible for what? Corel is not cutting software, it is design software. You need your cutting software compatible with Corel 11, then your cutting software has to be compatible for the Copam. What cutting software are you using? The cutting software has the drivers to operate your vinyl cutter. Corel does not have drivers or any feature to adjust blade offset, which you will need. Share this post Link to post Share on other sites
