Poot25 9 Posted December 11, 2012 Hey guys, I have the CorelDraw X3/ Cutting master plugin combo that came with my Graphtec CE-5000-60 cutter. I have just started trying to use the CM2 as part of my cutter after buying some Papilio vinyl to try. The problem I have run into is that doing a test of the vinyl when I load and set up I am able to print the image with registration marks, then when I try to contour cut around itafter printing it told me that I didnt have my cutter set up. I went to the graphtec website and downloaded the driver for my cutter and downloaded it to my computer. I got the drop down to come up on the cutter portion now but it gives me an error when I try to contour now. Any help would be greatly appreciated. JP Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 11, 2012 If your using Cutting Master 2, make sure the cutter Command is on GP-GL Share this post Link to post Share on other sites
Poot25 9 Posted December 12, 2012 Thanks Skeeter, I will look at that tonight. Share this post Link to post Share on other sites
emjay78 0 Posted December 20, 2012 hi... can we use cutting master 2 plug ins in pcut cto-630? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted December 20, 2012 hi... can we use cutting master 2 plug ins in pcut cto-630? Your question was answered on your other post.. Probably not, Cutting Master 2 is a Graphtec software.and is run on Graphtec language GP-GL. most cutter commands are HP-GL Share this post Link to post Share on other sites
