jpsegura
contour tool problem
I need help!
I need to do this sticker, can someone explain how to do it in corel drawX6 ,.
I tried scan but it does not come clear
any help will be apreciate it.
thanks in advance.
Your Best bet is to ask which fonts are used and duplicate it using fonts. Sorry I can't help with font identification but someone should be along that can tell what they are.
This won't be 100% perfect, but will work:
Type out your original text.
Duplicate, change the color and send it behind the original text. (You don't have to change the color of the text, but I find it easier to keep track of which is which if they are temporarily different colors).
Offset the duplicate text to create the shadow/3D effect.
Click back on the original text and add an outside contour the same color as the original text.
Line everything up so it looks good, change the color of the duplicate text to match the original.
Click on the contour group and press Ctrl-K to break apart the contour group.
Select the original text, the duplicate text and the contour and Arrange > Weld them together before cutting.
