tservice 3 Posted November 13, 2012 I am making equipment label that is printed I will be contour cutting them, but I need to also cu a hole in the center of the print. How can I make flexi do it? Thanks guys Share this post Link to post Share on other sites
dwp99 283 Posted December 11, 2012 I just posted this in another topic. 1. Select the item you want to contour cut around 2. under the Effects drop down select Contour Cut 3. Go to Design Central A. you can choose Contour, Rectangle or Ellipse B. You can choose how far out you want the cut from the graphic. You can even cut negative so the cut will take a little of the grapcic. C. If you want to cut out the holes in side the letters check the box marked with holes. D. Choose weather you want rounded corners or square corners. E. When you get that set click the green check 4. To add the registration marks click the rip print icon on the top tool bar. A. In there you can select the Graphtec Plotter. B. Below where you select the plotter is a drop down menu to choose the type of registration marks. Note: If you want to use your path edit tools on the contour cut right click on the graphic you want to edit the cut and click Separate Countour Cut. Now the edit path tools will work on the countour cut. That's as far as i can tell you because I don't have a printer so my rip/print section is not setup. Hope this helps. Share this post Link to post Share on other sites
