passion4signs 0 Posted November 7, 2012 Need some instruction/help. I have an inkscape file from the lastest version of inkscape that I have imported into flexi starter for cutting. The file was saved as both an svg and eps and the eps is the one I have imported. The issue I am having is the text does not appear when I attempt to cut only the parts I bitmapped. Do I need to bit map the text in inkscape and if so how is this done? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 7, 2012 you only need 1 post , check your other post.. Share this post Link to post Share on other sites
