minivipr 0 Posted October 26, 2012 I am having an issue with a location that wanted a lare wall decal done. during the install process the transfer paper was pulling the vinyl right off the wall. I used 631 but it just will not stick. The walls are not freshly painted. I even tried 651 to see if the extra adhesion would help. Is there anything I can do? I have thought about spraying the back with the glue from a can. What kind of paint works the best for walls to help the vinyl stick. Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted October 26, 2012 What type of transfer tape are you using? There is special tape for 631. http://www.uscutter.com/index/page/product/product_id/1755/category_id/14/product_name/ORATAPE+HT55+Decorative+Film+Transfer+Tape+for+631+Vinyl Also some paints has Teflon in it, and other additives.. So they are not good for decals. Share this post Link to post Share on other sites
mb20music 760 Posted October 26, 2012 Is the wall textured? you might need one of these http://www.signwarehouse.com/p-HT-M-X50006.html Share this post Link to post Share on other sites
michaelphay87 11 Posted October 26, 2012 if you need to make it stick more 3m makes a adhesive for general use i used it for foam seat covers on dirt bikes that might work check lowes or home depot Share this post Link to post Share on other sites
minivipr 0 Posted October 26, 2012 I got the whole graphic up but sections of it peel right down off the wall. Even without transfer tape the darn thing peels right off. I am using regular transfer tape. I have done stuff other places without issue. I think it's the paint that the location used. They are willing to repaint I think but I don't know what to tell them to use. Share this post Link to post Share on other sites
Dr12volt1338 116 Posted October 26, 2012 All the wall art I do if there is ANY texture to the wall at all it just takes patience.... Wrap your hard card with paper towel and keep pressing and pressing and pressing some more... Then slowly peel away your transfer pressing the actual vinyl when needed..... Also make sure the wall is very very clean watch what you clean the wall with as most all cleaners seem to be extra bad with leaving residue on painted walls.... Share this post Link to post Share on other sites
Jay2703 704 Posted October 26, 2012 Even with patience, vinyl will not stick to some paints. I use Lowes Valspar Semi-gloss and vinyl will not stick to it. Share this post Link to post Share on other sites
vinylmotivations 143 Posted October 26, 2012 A lot of paints vinyl will not stick to properly. There are some that are worse than others for sure! Share this post Link to post Share on other sites
knucklehead 530 Posted October 27, 2012 I did one with the 'cleanable' paint, that wouldn't stick. I marked out a section where the graphic would go, kinda close to the design, and took a GREY scotchbrite pad, and some alcohol and scuffed the paint pretty good. It did stick with a little effort, haven't heard anything about it coming off. Haven't asked either. Share this post Link to post Share on other sites
ramy 3 Posted March 21, 2013 I also, just ran into this. Would the seal it pen work? Share this post Link to post Share on other sites
