jgeck90
Jagged edges after vector
Why is this happening? Is it because of low quality picture? As you can see the small text looks nothing like it did before. It's now jagged and not even square.
Any help would be appreciated.
Jeff.
Yes like lizzy says. Try not to convert text. It requires to much work.
Your also probably using the wrong threshold when you convert it. Whenever I trace bitmap something, I do at least 5 test traces. Usually more like 15 tries before I get it to a good starting point. They will always, ALWAYS, need to be cleaned up by editing the nodes but tracing it a few times with different thresholds lets you see what setting works best for that picture. Not all pictures are the same, so no threshold works for all pictures.
