muibubbles 2 Posted August 14, 2012 Ok this may be a bit more complex then i can explain so i'm going to try and simplify it.. 1. I drew a triangle shape (rotor) with the bezier tool. When i send it to SBE and cut it, it actually cuts the line thickness vs just the shape. -line weight is 1px -there is stuff inside the triangle so i can not just "fill it" -in order to keep the nice straight lines (not jagged) i have to go to PATH and then convert STROKE TO PATH (if i dont do this, in SBE the lines become multiple line segments 2. The two pieces in the green outline can be filled in, but when i fill it in, SBE treats it like a 150+ line segments and becomes what is equivalent to 50 sided octagon instead of a circle. ALSO the "gear" gets cut into 10000 pieces versus one continuous line SO, i did PATH then convert STROKE TO PATH which makes it what you see now, so now im weeding 3 lines right next to each other vs 1 (for the rings) and the gear im pulling about 20 teeth out + the 2 lines any suggestions/help? Share this post Link to post Share on other sites
mfatty500 456 Posted August 14, 2012 Not familiar with that program, but it sounds like you need to weld it. Share this post Link to post Share on other sites
Acrylic Conceptions 5 Posted August 15, 2012 If you work with your layers..couldn't you fill it and then put it to the back? Share this post Link to post Share on other sites
JP Auto N Design 36 Posted August 16, 2012 I think i follow ya....sorta... First, you can make that triangle shape wit the "star" tool. Just change the sides to 3 then tweak it to get the bowed look. Now if you want the triangle to have fill but still have the designs cutout in it, i would start wit the filled triangle then start puttin your designs in place and use the "difference" feature (at the top PATH>DIFFERENCE). It might take a little trial n error to get it right since you got pretty much goin on there. As far as the others you have highlighted in green, i would just try PATH>UNION for those. Not sure if i'm way off what youre tryin to achieve but hope it helps somewhat. Share this post Link to post Share on other sites
