strycnine 23 Posted August 3, 2012 I have this EPS and when I send it to Signcut the center is missing. How can I fix this? celogo1.eps Share this post Link to post Share on other sites
cmwyke 0 Posted August 3, 2012 What is the center that you are referring to that is missing? It all appears to be there to me. Share this post Link to post Share on other sites
cmwyke 0 Posted August 3, 2012 I don't know much about Signcut itself, but maybe try a different file format? pdf, ai, svg, something like that? If you need it converted to any of those, let me know. Share this post Link to post Share on other sites
strycnine 23 Posted August 3, 2012 It was ai, but i converted it to eps. It wouldn't open in Corel as an ai Share this post Link to post Share on other sites
cmwyke 0 Posted August 3, 2012 not sure what to say then, kind of crazy really Share this post Link to post Share on other sites
strycnine 23 Posted August 3, 2012 What program do you use to cut with? Share this post Link to post Share on other sites
cowboy_1_831 28 Posted August 3, 2012 Here is just the logo, you will need to add the text back. It had a BUNCH of layers. How this helps you out celogo only2.EPS 1 Share this post Link to post Share on other sites
strycnine 23 Posted August 3, 2012 Here is just the logo, you will need to add the text back. It had a BUNCH of layers. How this helps you out Thanks brother! Share this post Link to post Share on other sites
smokeybearfan 87 Posted August 3, 2012 I opened it in sign cut it had 10 extra layers. once those were deleted it looks ok. Share this post Link to post Share on other sites
strycnine 23 Posted August 4, 2012 Smokey, I'm still at the newbie level. How do I delete the extra layers? I have Corel. Share this post Link to post Share on other sites
smokeybearfan 87 Posted August 4, 2012 Don't use Corel. I just deleted then in sign cut or AI Share this post Link to post Share on other sites
Sue2 920 Posted August 4, 2012 In Corel, ungroup your graphic then go to the VIEW drop down menu and click on Wireframe. Now all you will see are outlines of the objects on your page...no fills. These outlines are the cut lines for your cutter. If your object has both line and fill, you will see this in wireframe view and you can eliminate those extra cut lines. If the extra layers are exactly on top of one another you won't see them until you delete one. If you select one object, hit delete and the outline remains...you have hidden layers. Delete until you get to only one. If you remember that what you see in wireframe is EXACTLY where your cutter blade is going you can correct many things before ruining good vinyl. Sue2 1 Share this post Link to post Share on other sites
strycnine 23 Posted August 4, 2012 Thanks for the help smokey and sue! Share this post Link to post Share on other sites
