mxracer394 22 Posted July 23, 2012 im trying to cut some oracal fluro. I cant get it to cut all the way thru i havelowered the blade and made no difference..pressure is still on 1g. i dont want to keep trying to adjust it cause that fluro aint cheap...any ideas Share this post Link to post Share on other sites
slice&dice 2,450 Posted July 24, 2012 Are you saying that this "fluro" (?) material is thicker than regular vinyl? If so, the pressure would have to be INCREASED to provide more downward force. Share this post Link to post Share on other sites
mxracer394 22 Posted July 24, 2012 Ten four tbe fluro is 6mil. I figured lowering the blade would work.will try raising pressure tonighy Share this post Link to post Share on other sites
vinylmotivations 143 Posted July 24, 2012 Same blade as regular vinyl, up the pressure double normal most likely Share this post Link to post Share on other sites
Snapper 30 Posted July 24, 2012 If you don't want to play with your settings... just select number of passes as two. The cutter will cut it twice going over the same path. Share this post Link to post Share on other sites
slice&dice 2,450 Posted July 24, 2012 Where in Sign Blazer do you have that option of "two passes" ?? Share this post Link to post Share on other sites
Coaster36 327 Posted July 24, 2012 Signblazer doesnt have that option. Flexi has it, Id be worried about alignment issues using that option. Although I have never tried it, I dont know how it goes about the process. Share this post Link to post Share on other sites
mxracer394 22 Posted July 24, 2012 went from 1 to 150 on pressure and it turned out okay.... thanks for the help Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 24, 2012 Signblazer doesnt have that option. Flexi has it, Id be worried about alignment issues using that option. Although I have never tried it, I dont know how it goes about the process. I think it could be done in Signblazer,,,, copy on top of each other.. and it would take a good tracking cutter Share this post Link to post Share on other sites
slice&dice 2,450 Posted July 25, 2012 went from 1 to 150 on pressure and it turned out okay.... thanks for the help You're welcome. Share this post Link to post Share on other sites
