fourthsyde
cutter is double cutting and pulling parts off of graphic
So for some reason, my cutter is double cutting the little needle in this graphic.... when it does that, it pulls the needle up off the paper because its so small.... is there something wrong with the graphic thats making it trace over this one part? what else could it be?
thanks!
RL single color logo.eps
nah... the face of the gauge was meant to be left open...
when i cut, i selected the red only, but it still doubled the cut....
Guest fivestar
foruthsyde I just cut the graphic you posted and it cut fine on mine.  Make sure there isn't a setting in your software that has it cut more then once.  I am using flexi and I know there's a setting in there where you can set it to cut more then once.
double cutting is often caused by layers ....colors generally is the cause.
mark-s
Also make sure you haven't inadvertently added an outline to your text or graphic. I have a tendency to do this in Corel Draw without noticing I have gently squeezed the mouse buttons.
Thanks for posting the solution. It ALWAYS helps others when the same situation comes up. Glad you got it solved.
