ff-extreme
addtional pinch roller
Hi everyone, I received my addtional pinch roler today but it came with no instructions. does anyone know how to put this in. Also I was told I could remove a metal part on it so the cutter will ignor it when it measures ( im adding it as a 3rd for the center)
Thanks
Looking at the back of the cutter on the right hand side you will see a big screw with a rubber O ring that keeps the pinch roller from going all the way to the right side of the cutter. Remove that screw, plus the two little screws that hold a little metal plate in place. Once screws are removed, remove the little metal plate, and now you can slide the pinch roller out, remove the little silver dot on the front of the pinch roller with a nail or something, then put it back on, then add the new pinch roller. This way the pinch roller without the silver dot will be in the middle of the other two. Put the plate back on and the screws back in. Done.
:P
