Tabtrade 0 Posted June 8, 2012 Hi, Can any one Identify what make and model this cutter might be and if so how to get it to do a test cut without connecting it to a pc ? The name on it is Jinling Like !, I assume its something standard with an obscre name on it , its quite ols as it only has serial connection. Thanks for any info ! Share this post Link to post Share on other sites
Dr12volt1338 116 Posted June 8, 2012 From what I gather and have found it is either a Jingling 610 or Jingling 710. It appears the 710 was more common and very popular in the UK and England.... I would suggest trying one of the uscutter sc series drivers..... If it is indead a 710 unit... Which is 710mm cutting width then that is roughly a 30" unit so any of the SC units that are of that size I would start there..... I am sure one of the Chinese drivers will work I just was not able to locate an exact driver.I know people have had good luck with Copam drivers working... I believe the LiYU is a pretty generic driver also.... You will just have to play around until you find one that works properly.... Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 8, 2012 Hello, welcome to the forum. In answer to your specific question, once you have the vinyl inserted under the blade-holder carriage, press the OFFLINE button, and see what comes up in the LCD display window. You may beed to cycle through various choices to obtain "test cut" --- A test cut should result in a small square with diagonal lines crossing through it. First thing you might want to do since it's an older machine, is replace the blade. 1 Share this post Link to post Share on other sites
