xpfguy 39 Posted March 4, 2012 any advice on how to prevent the glazed look where the press platen contacts shirt? example: Fibron material, 340 deg, 20 seconds, firm pressure, teflon sheet between heat platen and the graphic. Transfer express #'s at 375 deg for 4 sec does the same thing. using the 15/15 digital from usc is the result normal when pressing on poly (under armour) type shirts? i will try and post a pic when i find one. Share this post Link to post Share on other sites
markvvq 14 Posted March 4, 2012 Are you using easy weed designed for cotton or cotton poly blend? They make other vinyl for low temp applications. Mark Share this post Link to post Share on other sites
