spitfire 0 Posted January 22, 2012 MY setup MH-871 USB connection Windows 7 SignBlazer and Signcut Here is the problem. I can't get anything to cut. I have followed the newb manual and it didn't help. I assume from reading on hear that Keyspan will be the solution but want to make sure before I go ordering one. I have the image in SignBlazer no problem. All connections ports etc seem to be correct. When I go to Cutter-Cut-Cut Tile the blade will drop to the vinyl on the cutter but it won't cut out so since when I hit cut tile the cutter responds by dropping the blade to the vinyl that my PC is communicating with the cutter it's just not cutting. So just trying to make sure the Keyspan will solve that problem or do I maybe have a setting incorrect somewhere? The cutter itself work fine. I can do test cuts from the cutter no problem. Thanks for any help. Share this post Link to post Share on other sites
slice&dice 2,451 Posted January 22, 2012 Can you provide a Screen-shot here of your Cutter Setup dialogue box? Share this post Link to post Share on other sites
spitfire 0 Posted January 22, 2012 Hopefully this is what you want. Baud 9600 Data Bits 8 Parity None Stop bits 1 *Hardware Share this post Link to post Share on other sites
slice&dice 2,451 Posted January 22, 2012 Change it to COM4 -- see if that helps. (in the "Output Device" drop-down menu there at the top of your Cutter Setup dialogue box) Share this post Link to post Share on other sites
spitfire 0 Posted January 22, 2012 Tried that. Didn't work Here is my options I selected blazer com4 and this was the error I recieved Share this post Link to post Share on other sites
spitfire 0 Posted January 22, 2012 So I have an update. My brother in law is here with his laptoip running XP using SignBlazer as well. He can get communication with the cutter but hitting cutter-cut tile and then the blade drops just as it does for me. But then he hits Maz Position and then home position the cut tile and it starts to cutout. Problem with that is it won't complete the cut for example we did the work ROCK and only this cut RO K it skipped the C and also it is not lifting the cutter blade as it making the cuts so its cutting all the tracking lines as well. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted January 22, 2012 Have you tried support? give them a call and explain whats going on maybe they can give you a souloution. Dan Share this post Link to post Share on other sites
spitfire 0 Posted January 22, 2012 I'm calling them tomorrow. Thought I would start here since they are closed today. Share this post Link to post Share on other sites
