lawman12 3 Posted August 23, 2011 I need to vectorize this and my program will not let it show up after importing. Would anyone want to take on this challenge? TIA Bruce viking.PDF Share this post Link to post Share on other sites
jfought 120 Posted August 23, 2011 not going to happen. way to light. Share this post Link to post Share on other sites
roxanneupnorth 106 Posted August 23, 2011 not going to happen. way to light. Ditto..... Share this post Link to post Share on other sites
mark-s 1,126 Posted August 23, 2011 Hand trace, scan, vector, node edit. mark-s Share this post Link to post Share on other sites
vinylmotivations 143 Posted August 23, 2011 I will give it a shot... just because some of these guys said not possible. no promises tho and no idea how much time I will have... Share this post Link to post Share on other sites
Neuromax 97 Posted August 23, 2011 It can be done but only like Mark said, it must be traced. Share this post Link to post Share on other sites
welder.man 3 Posted August 23, 2011 Here is my attempt, it still needs a lot of work but it might be a start. 0956.pdf Share this post Link to post Share on other sites
lawman12 3 Posted August 30, 2011 Here is my attempt, it still needs a lot of work but it might be a start. looks great, thanks Share this post Link to post Share on other sites
JoeDirt 5 Posted August 30, 2011 here is my attempt with the eps file also, you can un-compound and get just the white part if needed. viking2.eps Share this post Link to post Share on other sites
lawman12 3 Posted August 31, 2011 here is my attempt with the eps file also, you can un-compound and get just the white part if needed. what program are you using to un-compound and get just the white part. looks great, one day I will be the one offering my help to the newbies Share this post Link to post Share on other sites
JoeDirt 5 Posted August 31, 2011 Any program I think can un compound. But here it is. I think it may need some cleanup still. viking3.eps Share this post Link to post Share on other sites
