Carlosgraphic 0 Posted July 17, 2011 Hello! I'm new in this forum. Well, my question or problem (I don't know yet) is the following. I recently bought a MH-871 uscutter. I installed it follow to the instructions. The cutter is working with flexisign software, but I have seen something strange on the cutter. When I cut something, it finish well, but the carriage stops in the last cut point. I have to push the reset button, so the carriage come back to initiation. The cutter doesn't make it by itself after a job or cut. In consequence, If I leave the carriage in the last cut point, and I wanna do another cut then the cutter begin a erratic cut. I have to cancel the printing/cutting job, push offline/pause, and turn the cutter off and come back turn it on again. In addition, I cannot print again if I only push offline/pause and I cancel a printing/cutting job. I have to turn off/on the cutter necessarily. Thanks. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 18, 2011 what version of Flexi? and on what type of computer operating system? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted July 18, 2011 Hello! I'm new in this forum. Well, my question or problem (I don't know yet) is the following. I recently bought a MH-871 uscutter. I installed it follow to the instructions. The cutter is working with flexisign software, but I have seen something strange on the cutter. When I cut something, it finish well, but the carriage stops in the last cut point. I have to push the reset button, so the carriage come back to initiation. The cutter doesn't make it by itself after a job or cut. In consequence, If I leave the carriage in the last cut point, and I wanna do another cut then the cutter begin a erratic cut. I have to cancel the printing/cutting job, push offline/pause, and turn the cutter off and come back turn it on again. In addition, I cannot print again if I only push offline/pause and I cancel a printing/cutting job. I have to turn off/on the cutter necessarily. Thanks. None of the refine cutters recognize the 'advance after cut' feature and you have to reset after each cut. It is he one thing I do not like about them. Share this post Link to post Share on other sites
Carlosgraphic 0 Posted July 18, 2011 what version of Flexi? and on what type of computer operating system? Flexisign 8.6 and Windows 7 64 bits. Postdata: It works well with SBE, but I would like use Flexisign because It is less complicated to import images from AI. I'm unable to import some images from AI to SBE, but I can do it with Flexisign. I think flexi is more friendly than SBE or SC. I can import images without problem, make single designs and move them on preview before cut. Share this post Link to post Share on other sites
Rodger 527 Posted July 18, 2011 All of them are friendly after you learn each 1s settings . SignBlazer has been the easiest software I have tried . I don't do very complicated stuff , so it does everything I want . Share this post Link to post Share on other sites
