forsalevinylsigns 1 Posted April 3, 2011 Hello everyone, I just finished building a custom pc, its got windows 7 64 bit. The reason i built this is because i want a faster machine. I tried installing Flexi sign 7.6 on it and it did, but I cant open it because I have a 64 bit OS. What do you guys use as a cutting program or recommend for a 64 bit machine? Thanks!!! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 3, 2011 Hello everyone, I just finished building a custom pc, its got windows 7 64 bit. The reason i built this is because i want a faster machine. I tried installing Flexi sign 7.6 on it and it did, but I cant open it because I have a 64 bit OS. What do you guys use as a cutting program or recommend for a 64 bit machine? Thanks!!! I don't have 64 bit, but Flexistarter supports it, I have been using Flexistarter for over 4 years, as my cutting software. Flexistarter 10 runs smoothly on windows 7 system, 64bit or 32bit , than any previous versions of flexistarter software. Inadditional to that, Flexistarter 10 also runs smoothly on Windows Vista (32bit, or 64bit), and Windwos XP system. Flexi10 sets a new industry standard with robust new features geared toward maximizing production, all while striving to create a sustainable future. Flexi excels as a one-stop software solution with a wealth of industry-specific design tools, thousands of drivers to run cutters, printers and hybrids, all wrapped in an intuitive, easy-to-use interface. FlexiStarter 10 has the most powerful import filters, which can open your design files from Adobe CS or Coreldraw software and many other vector based design software. Share this post Link to post Share on other sites
NukleoN 34 Posted April 3, 2011 Hello everyone, I just finished building a custom pc, its got windows 7 64 bit. The reason i built this is because i want a faster machine. I tried installing Flexi sign 7.6 on it and it did, but I cant open it because I have a 64 bit OS. What do you guys use as a cutting program or recommend for a 64 bit machine? Thanks!!! I also run Win-7x64 and SignCut Productivity Pro works perfectly for me. It's subscription-based, but fairly inexpensive. I also use 64-bit Photoshop and love that my 64-bit OS can support all 8GB of my RAM! Share this post Link to post Share on other sites
stetson5331 80 Posted April 3, 2011 I also run Win 7 64 Bit and run Flexi 10 Pro.. runs great Share this post Link to post Share on other sites
racinboy30 9 Posted April 3, 2011 Hello everyone, I just finished building a custom pc, its got windows 7 64 bit. The reason i built this is because i want a faster machine. I tried installing Flexi sign 7.6 on it and it did, but I cant open it because I have a 64 bit OS. What do you guys use as a cutting program or recommend for a 64 bit machine? Thanks!!! Right click, run as administrator. Windows 7 pro and ultimate omly. If you have home I can not guarantee it will work. Both pro and ultimate are backwards capable and should have no problem running any software even for xp, windows 98. I have windows 7 pro and have no problem running any software. Share this post Link to post Share on other sites
