ssfx 0 Posted March 15, 2011 during the cutting process cutter stopped in about the same place both times i tried to cut a simple text sign. cutter window says that it is still cutting but it is not. cutter is refine mh721, any ideas? Share this post Link to post Share on other sites
racinboy30 9 Posted March 15, 2011 during the cutting process cutter stopped in about the same place both times i tried to cut a simple text sign. cutter window says that it is still cutting but it is not. cutter is refine mh721, any ideas? Make sure in the setup window in cutter interface in signblazer, that the length is set at some large number like 5000 or something and see what happens. It may be set too low and not know there is any more vinyl. Share this post Link to post Share on other sites
Jay2703 704 Posted March 16, 2011 What type of connection are you using? I had problems with my USB connection and it did that. I switched to a serial connection and it solved my problems. Share this post Link to post Share on other sites
