firemalt 10 Posted January 17, 2008 in another sub-forum... and it made me curious about SBE. Can you type text in a column? If so, how? Share this post Link to post Share on other sites
kenimes 42 Posted January 17, 2008 The only way I found, and it may not be right, but type your text and select it, then click on Edit, then Edit Text. You can now click on the little boxes by each letter and drag them to column form, one by one. :notsure: Share this post Link to post Share on other sites
firemalt 10 Posted January 17, 2008 Well, that's the way I've been it in the past... I was curious if there if a faster/better/easier way to do it with SBE? Share this post Link to post Share on other sites
Jerry Bonham 1 Posted January 17, 2008 Hello, I assume that you are talking about vertical text? It is easy. In the text editor choose centre justify. Type one letter Press enter. Type the next letter and so on until you have typed the word you want. Then in node edit you can easily adjust the spacing between the letters Trust this helps Jerry from SignBlazer. Share this post Link to post Share on other sites
