may0024 0 Posted March 11, 2011 I have multiple files that I would like to share with a friend. They are Flexi jobs, but she uses Sign Blazer. I'd like to save them in a format that allows her to edit text. What would be my easiest route? TIA for your help. Share this post Link to post Share on other sites
Rodger 527 Posted March 11, 2011 I have multiple files that I would like to share with a friend. They are Flexi jobs, but she uses Sign Blazer. I'd like to save them in a format that allows her to edit text. What would be my easiest route? TIA for your help. I know SignBlazer can import EPS files . Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 11, 2011 I have multiple files that I would like to share with a friend. They are Flexi jobs, but she uses Sign Blazer. I'd like to save them in a format that allows her to edit text. What would be my easiest route? TIA for your help. I have this saved,from a member here, but haven't tried it, this refers to CutStudio, which is the Flexi version for Roland, I have been using CutStudio for years and had the same problems. What I do if I need to simply convert one of my .cst files is have the design open in cutstudio ; click/highlight the actual artwork I want to convert and copy it to the clipboard (CTRL-C); then open Signblazer (which is free) and then PASTE (CTRL-V) it into an open session of Signblazer. Then resize it in Signblazer, and hit CTRL-E (or go to FILE and EXPORT) in Signblazer and it will take you to the Export Screen ; at the bottom left corner of the screen, change the file type to .EPS, give it a file name, select the location folder to save it to and click OK. Sounds like alot but it only takes a few seconds and it works great for me! Share this post Link to post Share on other sites
may0024 0 Posted March 11, 2011 I have this saved,from a member here, but haven't tried it, this refers to CutStudio, which is the Flexi version for Roland, I have been using CutStudio for years and had the same problems. What I do if I need to simply convert one of my .cst files is have the design open in cutstudio ; click/highlight the actual artwork I want to convert and copy it to the clipboard (CTRL-C); then open Signblazer (which is free) and then PASTE (CTRL-V) it into an open session of Signblazer. Then resize it in Signblazer, and hit CTRL-E (or go to FILE and EXPORT) in Signblazer and it will take you to the Export Screen ; at the bottom left corner of the screen, change the file type to .EPS, give it a file name, select the location folder to save it to and click OK. Sounds like alot but it only takes a few seconds and it works great for me! Hmm, so maybe I can try to copy and paste to SB and save as a SB file type? I'll tell her to try that route. I've exported them as eps, but she's unable of course to edit the text. Thanks both of you for your help & input! Share this post Link to post Share on other sites
Rodger 527 Posted March 11, 2011 I missed the edit text part . If the way Skeeter does not work , you can " arrange " - " split " in SB to edit stuff . You then " combine " when you get done . Share this post Link to post Share on other sites
