h2ylm 0 Posted January 23, 2011 hi can anyone clean this for vector?? or even tell me how to do it, ive uninstalled my castope light and reinstalled - but no use, i traced on corel draw - but there are lots of extra cut lines and i cant see the proper image when opened in vector software, thank you in advance Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 23, 2011 maybe try inkscape.org... FREE software, Vectorising in Inkscape SolutionThis walk through explains the basics of vectorising in Inkscape. Step 1) Import your image. Click File>Import, find your file and click OK. Step 2) Select the image, go to the top of the screen, click Path>Trace Bitmap. Step 3) The Trace Bitmap menu will then open. Here you can select how you want your image vectorised and adjust the settings. You can also generate a preview. Once you are happy with the preview click OK and close the Trace Bitmap screen. Step 4) Now you will have your new vector image and the old raster (bitmap, jpeg, gif etc) image stacked on top of each other. Seperate the two and delete the raster. Step 5) Play around with your new vector image! Share this post Link to post Share on other sites
deth502 39 Posted January 23, 2011 its pretty small, a larger pic would help you get a cleaner easier trace. Share this post Link to post Share on other sites
slickhick 2 Posted January 23, 2011 heres a vector needs some clean up inkscake should work to clean it up zumba.eps zumba.eps Share this post Link to post Share on other sites
h2ylm 0 Posted January 23, 2011 Wow, Thank you all for your help - really appreciated, I will play around with that tonight, Will let you know how I get on, Thanks again Share this post Link to post Share on other sites
h2ylm 0 Posted January 23, 2011 Hi I must be doing something wrong, cos when i click ok - to start the trace - nothing happens? have i missed something, sorry to be a pain.... Share this post Link to post Share on other sites
deth502 39 Posted January 23, 2011 slick posted an eps file, and while inkscape wont work to clean it up, since you cant import an eps into inkscape, you dont need to run a trace on it, as it is already in vector format. Share this post Link to post Share on other sites
h2ylm 0 Posted January 23, 2011 Thank you to everyone for their help, I cut a small one of these todat to try and it looks good, as usual a lot of wasted vinyl, so i cut and pasted my original image in paint, trying to get that to cut - but again the inside of the letters show wee white lines - a bit like sewing lines, so i will keep trying Thanks again Share this post Link to post Share on other sites
deth502 39 Posted January 23, 2011 try this zumba.EPS zumba.EPS Share this post Link to post Share on other sites
h2ylm 0 Posted January 24, 2011 thank you i will give it a go Thanks again Share this post Link to post Share on other sites
