godstrong1 2 Posted January 20, 2011 What kind of vinyl is used to apply vinyl on the inside of a store front window. Thanks Share this post Link to post Share on other sites
Neuromax 97 Posted January 21, 2011 What kind of vinyl is used to apply vinyl on the inside of a store front window. Thanks The same vinyl that is used for the outside of a window. Just cut it in a mirror image. The one thing you need to keep in mind is that the sticky side does not have UV coating like the finished side. If you don't have any direct UV exposure it will work great. If you do have UV exposure it will still look great but will not last as long. Share this post Link to post Share on other sites
vectorman 0 Posted February 2, 2011 hi somtims i see some very very small dots of sand when im applaing wet , u can see it even from the insid & outside im talking about smal very small dots ' not bubbels but sand. its very hard to get rid of them any idias? anyway if u use water soap on dark yianil u will get white stains i the inside so if u can dont use soap or put just a bit Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 3, 2011 Oracal advises against it because of exposing the adhesive to the uv Share this post Link to post Share on other sites
racinboy30 9 Posted March 2, 2011 hi somtims i see some very very small dots of sand when im applaing wet , u can see it even from the insid & outside im talking about smal very small dots ' not bubbels but sand. its very hard to get rid of them any idias? anyway if u use water soap on dark yianil u will get white stains i the inside so if u can dont use soap or put just a bit Use a fresh razor blade scrapper on the window first. It will remove 99.9% of all the dirt or anything else on the glass. Then use a orange clean solvent to clean it up all the way. Share this post Link to post Share on other sites
